AML1618
Feb 27, 2019Aspirant
difference in Nighthawk M2 MR2100 & M1 MR1100
What is the difference between MR2100 & MR1100
- Mar 04, 2019
Hi AML1618
Thank you for your interest.
Nighthawk M2 Mobile Router (MR2100)
- LTE CAT 20, DL support up to 2Gbps speeds
- 3GPP, Rel. 14
- 5CA with 20 simultaneous Downlink layers
- 4x4 MIMO
- 256QAM DL / 64QAM UL CA 3C, 7C
- 11ac Dual band dual concurrent
Nighthawk M1 Mobile Router (MR1100)
- LTE CAT 16, DL support up to 1Gbps speeds
- 3GPP, Rel. 12
- 4CA with 10 simultaneous Downlink layers
- 4x4 MIMO
Blanca
Community Team
MAJOR-z-BOMBASU
Apr 15, 2019Guide
LTE CAT 20, DL support up to 2Gbps speeds sounds great,
but what about wi-fi connection? Is it still 2x2 mimo as it is in MR1 1100 ?
With ethernet limited to 500Mbps and Wi-Fi connection limited to 867 Mb[s (2x2 mimo 5gh 80mhz wide channel) we will never reach more than 867Mbps ....
