AML1618
Feb 27, 2019Aspirant
difference in Nighthawk M2 MR2100 & M1 MR1100
What is the difference between MR2100 & MR1100
- Mar 04, 2019
Hi AML1618
Thank you for your interest.
Nighthawk M2 Mobile Router (MR2100)
- LTE CAT 20, DL support up to 2Gbps speeds
- 3GPP, Rel. 14
- 5CA with 20 simultaneous Downlink layers
- 4x4 MIMO
- 256QAM DL / 64QAM UL CA 3C, 7C
- 11ac Dual band dual concurrent
Nighthawk M1 Mobile Router (MR1100)
- LTE CAT 16, DL support up to 1Gbps speeds
- 3GPP, Rel. 12
- 4CA with 10 simultaneous Downlink layers
- 4x4 MIMO
Blanca
Community Team
Apollon
Mar 13, 2019Apprentice
I'm network and software engineer, among other things, and really didnt need that 101 class, or any "cliarifications". In my area, my carrier just upgraded the cell towers in 2018 with the newest hardware available, and all towers here support multiple carrier aggregation. When I say "mulltiple" I dont mean 2 or 3 - I mean enough to max out all nighthawks CA capabilities. Your speculation that CAT20 LTE radio is only 2-3%, or even 10% faster than CAT16 is unfounded and incorrect. Look up LTE category specifications, specifically supported speeds, before posting.
Either way, I'm not interested in an argument, or even in a discussion - I posted in the thread with the sole purpose to have my 2 questions answered by Netgear staff (Hi Blanca_O , how you doin'? :smileylol:), not to get opinions/speculations from users. Would have used live chat support, in order to avoid exactly this type of "chiming in" from regular users, if Netgear provided one.
phillipmcmahon
May 03, 2019Guide
Apollon you know YOU can always choose NOT to respond to "regular users" "chiming in". Otherwise you are only encouraging the silly unwashed plebs to engage with your higher intellect...
