DariusG_TMUS_SE
Dec 04, 2019Aspirant
Disable Master Reset
Is it possible to restrict the ability to perform a master reset via the hardware keys or pin hole, or from the admin menu?
- Dec 10, 2019
Welcome to NETGEAR Community!
There is no option to disable the ability to factory reset the device via hard reset or soft reset.
Blanca
Community Team
Blanca_O
Dec 10, 2019NETGEAR Employee Retired
Blanca
Community Team
