chrismholmes
Oct 21, 2024Follower
Disable SSID and password info on MR6150
Does anyone know if you can disable the QR function on the MR6150?
When hiding the SSID name and password, if you touch the QR icon on the device it still shows the WIFI name and password!
Ultimately, we would like to disable all features on the LCD, only displaying the number of connections and signal strength. (Like their legacy devices prior to this model.)
Side note: I enabled a passcode feature, but the funny thing is you can't enable the passcode on the web admin portal, only on the device itself, but then you have to have the passcode to turn the device off....
By enabling the passcode, I can no longer see the number of connected devices.
This device does not seem to be built with actual security in mind....
No RepliesBe the first to reply
