true1bagheera's avatar
Jul 03, 2019
Disabling WiFi on Nighthawk MR2100
Intend to use the M2 MR2100 as a Modem only i.e. connect the device via Ethernet to an existing Netgear WiFi router. For this purpose I need to disable WiFi on the M2 but I can not find this feature ...
