Helg1
Jul 03, 2015Follower
Do AirCard 785 support external WiFi antennas?
This review says it does. But i don't find any information about it elsewher: Is it realy true that you can connect 2 WiFi-antennas to the TS9-connectors on the Aircard 785? Or are they only for get...
Fairytail
Jul 03, 2015Virtuoso
Check these links.
http://kb.netgear.com/app/answers/detail/a_id/23901
http://kb.netgear.com/app/answers/detail/a_id/23385/~/how-is-the-external-antenna-connected-on-the-aircard%C2%AE-76xs-mobile-hotspot%3F
The Antenna is to boost your connection from the ISP and not for WiFi connection.
