DWEED
Dec 02, 2019Aspirant
Do not broadcast WIFI signal MR1100 M1
Hi Problem in my M 1 not broadcast wifi signal and restart work more than 10 times and no response Is there a program for the work of manual update I can not enter 192.168.1.1 and I can not plug i...
Blanca_O
Dec 11, 2019NETGEAR Employee Retired
Hi DWEED
Welcome to NETGEAR Community!
Have you tried resetting the unit? To clarify the wired connection, what is the Ethernet / Local Area Connection Status? Is it Network Cable Unplugged? Unidentified Network?
Blanca
Community Team
DWEED
Dec 13, 2019Aspirant
Welcome Sir
I tried all the methods, the device does not recognize all the cables and the PuTTY program:
Is there a way to update the device or restore the device?
Without the back button of the device? Because I tried and did not benefit :"(
And the device is hung on the logo by itself
