babydy
Dec 15, 2021Follower
Does Mobile Routers works with different ISP in different country?
1 Reply
Depends on if the mobile router supports the bands they use and the ISP allows it to be used. Some have requirements for what mobile routers you can use. Others are more flexible.
Its not an easy, yes they do because its more complex..
Its a check with your isp
