Spectrum1
Dec 04, 2022Tutor
Does MR1100 consume SIM Data when not being used?
Hi All I plan to have the MR1100 powered on all the time as it will be located in the attic, so switching it on and off when it’s not being used will not be possible. The data SIM I will be using...
mli
Dec 05, 2022Tutor
If you leave the MR1100 connected to the 4G network it will consume a small (possibly tiny) amount of data to maintain that connection.
The main function which might consume more data is if the MR1100 finds a new firmware version has been release and automatically updates itself (I'm unaware of how to disable this function). Although even then the amount of data will not be massive.
The main case you might consume a lot of data without expecting it is if you leave a large number of small devices connected to the MR1100 but if the only device that might draw a lot of data is the laptop, this case does not apply.
There is a simple way to disconnect the MR1100's connection by unticking the box which allows it to consume data via its management page.
Instructions for how to access the management page and control cellular functions can be found in the manual: https://www.netgear.com/support/product/MR1100.aspx#docs
Spectrum1
Dec 06, 2022Tutor
Many thanks Mli
Yes, I can see the tick box next to ‘Data’ which I can untick to stop any 4G data consumption when the MR1100 is idle. It's a shame that you can't disable automatic firmware updates on the MR1100.
Luckily the MR1100 will only ever have a single PC attached to it, so no fear of a data leaky device anywhere.
- mliDec 06, 2022Tutor
Actually, Security -> Parental Controls and Security -> Schedule might be more appropriate for automatically cutting access.
I think an idle connection would struggle to use more than about 200 MB per month, and likely it will be a lot less.
