Aeoliswind's avatar
Aeoliswind
Follower
May 14, 2020
Does MR1100 work with Telus in Canada?
Before buying this mobile router would like to know it works with the Telus network in Canada, BC in particular.
Currently have a Netgear 4G LTE modem woith two gigabit eyhernet prots.
And will; it give me improved speed?
Thank you,
Juergen
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Aeoliswind
    Welcome to NETGEAR Community!
    NETGEAR has several different SKUs of the Nighthawk M1 Mobile Router products and each product has a specific set of bands that is supports based on the region that it is purchased in.
    Telus network is listed as one of the supported carrier. Before purchasing the product NETGEAR recommends that you check the list of the supported bands and ensure that the product you purchase is the correct product for your region and that the bands it supports are supported by your Internet Service Provider (ISP).
    What cellular bands are supported by MR1100 Nighthawk M1 Mobile Router?
    List of Carriers Supported by AirCard Hotspot
    Blanca
    Community Team
