mr6150user
Jan 08, 2023Aspirant
Does MR6150 support NR band n78?
From Technical Support Manual, I can find that the MR6150 supports 5G NR band n77, but not n78. As far as I know, the bandwidth of n77 (3300-4200MHz) includes the bandwidth of n78(3300-3800MHz), ...
JohnPeng
Jan 10, 2023NETGEAR Expert
n78 is not supported on MR6150. But it may be supported by future FW upgrade.
Thanks
John
mr6150user
Jan 11, 2023Aspirant
Thank you for replying.
Then, Which frequency band range can be used from the n77 band (3300MHz - 4200MHz) in MR6150?
Another question is, can I change the center frequency of the MR6150?
