Cgekv9
Jul 01, 2023Aspirant
Does Netgear nighthawk 6 work in Caribbean?
Hi, I just bought the Netgear nighthawk six from AT&T. I am currently in the US I will be moving to the Caribbean next year, specifically, Puerto Rico, Dominican Republic, and Suriname. I am curious ...
JT240Z
Jul 02, 2023Luminary
Unless the Caribbean has AT&T, you're out of luck unless you can get AT&T to unlock the device. Even then, it may not work depending on the frequency bands used by the Caribbean service provider. Assuming that you have an MR6500 or MR6510 since you purchased it through AT&T..
