NashPhillips
Jan 04, 2022Aspirant
Does Netgear R7000 router cycle in any way once every 60 seconds?
Nighthawk R7000, Firmware V1.0.9.88_10.2.88, Windows 10 ... I have a Bluetooth Stereo Speaker Interference once every 60 seconds. If it's the router cycling, I'd like to know, and if there is a fix I ...
Jan 04, 2022Guru - Experienced User
The R7000 doesn't have bluetooth so it shouldn't be impacting a bluetooth connection.
- NashPhillipsJan 04, 2022AspirantWhether or not the router has Bluetooth is irrelevant. Transmission at two point x GHz has the potential to interfere with Bluetooth at the same rate. Thus the question does the router cycle once every 60 Seconds.
- michaelkenwardJan 05, 2022Guru - Experienced User
NashPhillips wrote:
Thus the question does the router cycle once every 60 Seconds.What does that mean? Cycle what?
