NoADSL's avatar
NoADSL
Follower
Sep 15, 2016
Does the Aircard 810s have DynDNS (DDNS)?
I am looking at buying an Aircard 810s. I need to be able to remote control equipment that sits on the LAN side of the router. This can only be done if it supports DDNS as a static IP is not available. I cant find reference to DDNS in the manual but have seen references to it elsewhere.
Does anyone know if the Aircard 810s supports DDNS (DynDNS)?
Thanks in advance.
NoADSL.
  • Hello NoADSL
    I do not see any settings that allow DyDNS on the 810s.
    DarrenM
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello NoADSL
    DarrenM
