MikGarcia21
Aug 10, 2021Follower
Don't Know what I'm doing
Okay so i bought a router to help improve my wifi and a wifi extender but before i got to the extender i wanted to set the router up and get the nighthawk app set up as well. I have turned off myc wi...
Aug 10, 2021Guru - Experienced User
What router did you buy?
If you go to netgear.com/support/
type in the actual model number.
It'll take you to install guides, videos, manuals, and firmware.
Quite a wealth of information that can help with new installs.
