Sawman27
Feb 14, 2020Aspirant
Double NAT on xbox
Trying to play Xbox live and it’s saying I have a double NAT and a strict NAT. I only have the nighthawk hot spot. No router. I just need some guidance! Like Ethernet to the hotspot?? Orrr??? Anything...
schumaku
Feb 15, 2020Guru - Experienced User
Not uncommon providers are using NAT, Carrier Grade NAT (CGN), or abusing RFC1918 addresses with CGN for assigning the "pubic" IP address to your mobile/MR1100.
Sawman27
Feb 15, 2020Aspirant
So basically I won’t be able to play video games online?? That’s all I want.
- schumakuFeb 15, 2020Guru - Experienced User
Understood, but nothing the community here can change or enhance on your behalf. Start with challenging your mobile data provider with the keywords from above....
- Ksa3344Feb 17, 2020ApprenticeMake sure these settings are enabled,
settings - Advanced settings - other
UPnP
DLNA
