NoName2424
Jan 26, 2019Follower
Double NAT problem
Does anyone know how to get rid of double nat. I've got the lb1120 in bridge mode connected to my wifi router buy Ethernet cable. Everything works great except Xbox one keeps saying double NAT. Any he...
Rainbowmercury5
Mar 26, 2019Aspirant
I too have the same problem LB1120 ethernet to WRT32X and ethernet to Xbox one X. I havent found a solution either but for some reason my sons Xbox One original design on wireless has an open Nat.
Blanca_O
Mar 31, 2019NETGEAR Employee Retired
Hi Rainbowmercury5
Did you set LB1120 in bridge mode?
If the xBox One connected to WRT32X, do you still have Double NAT?
Blanca
Community Team
- Rainbowmercury5Mar 31, 2019AspirantYes, modem is in bridge mode and ethernet from wrt32x
- Rainbowmercury5Apr 05, 2019AspirantStill the same issue double nat in that configuration
- Blanca_OApr 15, 2019NETGEAR Employee Retired
Hi Rainbowmercury5,
Kindly port forward the xBox One on the LB1121. Here's the reference link to enable port forwarding:
https://www.downloads.netgear.com/files/GDC/LB1120/LB112x_UM_EN.pdf [page 38 - 40].
Blanca
Community Team
