NoName2424
Jan 26, 2019Follower
Double NAT problem
Does anyone know how to get rid of double nat. I've got the lb1120 in bridge mode connected to my wifi router buy Ethernet cable. Everything works great except Xbox one keeps saying double NAT. Any he...
Blanca_O
Mar 31, 2019NETGEAR Employee Retired
Hi Rainbowmercury5
Did you set LB1120 in bridge mode?
If the xBox One connected to WRT32X, do you still have Double NAT?
Blanca
Community Team
Rainbowmercury5
Mar 31, 2019Aspirant
Yes, modem is in bridge mode and ethernet from wrt32x
- Rainbowmercury5Apr 05, 2019AspirantStill the same issue double nat in that configuration
- Blanca_OApr 15, 2019NETGEAR Employee Retired
Hi Rainbowmercury5,
Kindly port forward the xBox One on the LB1121. Here's the reference link to enable port forwarding:
https://www.downloads.netgear.com/files/GDC/LB1120/LB112x_UM_EN.pdf [page 38 - 40].
Blanca
Community Team- SirguillotineAug 29, 2019InitiateThat doesn't work for me I need some help.
