marcusvenn
Mar 26, 2020Aspirant
Double Nat type xbox one, Nighthawk M2 mobile router
im struggling with double nat on my xbox, i need someones help as im about to frisbee this lovely router out the window my xbox one is giving me double Nat and strict.
JohnPeng
Mar 27, 2020NETGEAR Expert
Did you try to enable IP passthrough on M2?
marcusvenn
Mar 27, 2020Aspirant
Hey! Yes I tried the IP pass through, and used Ethernet and infact did loose the double NAT and got open NAT, but doing that disables the WIFI so only the Xbox can use the Internet....
So,, is there a way I can get a Ethernet HUB, split it to that then add WiFi in after ? So Xbox gets the priority?
