Speedsk8
Dec 28, 2019Tutor
Double NAT
Trying to grt rid of Double NAT on son's Xbox Have a Nighthawk LTE AT&T Modem thta directly feeds a unmanged switch. I have set the XBox to a static IP outside my DHCP pool, Set up the port forwardin...
- Jan 22, 2020
This has been found to be a NAT issue from my provider and on that side I have no control so it will just be what it is till the new fiber makes it to my area.
JohnPeng
Jan 22, 2020NETGEAR Expert
Could you please try to enable IP passthrough on MR1100 and see whether it will help to resolve your issue?
Thanks
Speedsk8
Jan 22, 2020Tutor
It does not that was one of the first things I did. I have found that my NAT issue is from the providerside and that I have no control over so it will just have to wait till I can get on the new fiber they are running .
