jdward's avatar
jdward
Follower
Mar 08, 2018
dual cell wireless solution (w/ LB1120)
I'm trying to create a dual cell wireless solution. Can I do the following:
1. NETGEAR LTE Modem LB1120 - which plugs into the Asus WAN port to give primary connectivity.
2.. Then for fail over, plug a 4g USB stick into the Asus.
3. Will the Asus router arbitrate between the best signal?
Doesn't have to be an Asus  router.  It's just the first one I came across with 4G support via USB...
1 Reply
  • Short answer is no i don't think your router will do that.. unless its made for load balancing..
