matt002
Oct 12, 2019Aspirant
Dual WAN setup LB2120?
Hi all, Hope someone can help please. I have two LB2120 4G modems. They run together feeding into a dual WAN setup on my ASUS router. Now both connect to the router fine, however I am uns...
Purduephotog
Mar 23, 2020Guide
First, what are you trying to do? Have failover? If that's the case, then you need to look up a protocol called "CARP"
If you're looking to 'gang' them together for more bandwidth, you'll need to look up bonding.
If you've already patiently explained what you needed elsewhere, I'm sorry, I missed it.
