BAPreschool
Apr 26, 2021Initiate
EE Nighthawk M1 Gigabit LTE Mobile Router(MR1100EE)
Hi, I have been using this router for almost two years with no issues. Suddenly it is displaying the message 'Your data connection is disconnected'. I have tried resetting the router, removing the S...
- Apr 26, 2021
did you check with the cellular provider?
Apr 26, 2021Guru - Experienced User
- BAPreschoolApr 26, 2021Initiate
Immediately after posting this, haha! All sorted, thanks.
