Joten
Sep 22, 2023Aspirant
EE unlocked Nighthawk MR2100-firmware update.
Can someone help please, as having spent hours reading the forums, I am none the wiser. As per the thread title, I have been gifted an unlocked EE Netgear Nighthawk MR2100 router, which constantly re...
BlueMist
Oct 26, 2023Aspirant
Do you use built in ethernet connection? I have noticed that MR2100 often reboot itself for no apparent reason (especially at boot) when ethernet connection is active.
Also it may have something to do with the power supply? I have now for instance switched from provided power supply to USB-C connection from my laptop and everything seems to be running fine. Maybe you can try that as well.
JohnPeng
Oct 26, 2023NETGEAR Expert
Please capture a model.json file and send it to me at jopeng@netgear.com with your community ID.
Thanks
