Krzysiek
Nov 20, 2021Tutor
Enabling n41 on MR5200-100EUS
Hello, I've bought MR5200-100EUS, but it turns out there's a difference betwen 100EUS and normal version in terms of n41 support. 100EUS lacks it, but normal does have it (but doesn't have n38). n41...
W1lliam
Nov 22, 2021Virtuoso
Both MR5100C-1BNCNS and MR5200-100NAS has n38/n41 supported, you can't now force to pick up non-supported band(s) from AT commands as the FW is filtering it out
Krzysiek
Nov 22, 2021Tutor
Thank you for the explanation. Well, now the weird thing is that European version of the model is filtering out the band required by European mobile network operators. It doesn't make sense to me.
- JohnPengNov 22, 2021NETGEAR Expert
Could you please specify which carriers require n41 in EU countries now?
Thanks
- KrzysiekNov 22, 2021Tutor
It is Plus (Poland) (MCC 260 / MNC 01). Well, I know only this one, which, unfortunately (for someone who bought 100EUS version), is my MNO :/
First, I thought they didn't activate 5G for my subscription, then the issue was explained: currently, they provide it only on band n41. There are plans to start offering "true" 5G on 3.*GHz frequencies someday, but it is nowhere near close future (regulatory issues). - KrzysiekNov 22, 2021Tutor
Fun fact: when I was looking for a moblie 5G router I couldn't find anything used or discounted. Right now I see a lot of Nighthawk M5 routers being sold on auction portals (e.g. allegro.pl, the most popular one in Poland) for half a retail price. And now I think I know the reason.
- KrzysiekNov 28, 2021Tutor
JohnPeng I found a list enumerating bands used by operators in ITU region
https://en.wikipedia.org/wiki/Mobile_network_codes_in_ITU_region_2xx_(Europe)#Poland_%E2%80%93_PL
Assuming this list is up-to-date, Plus is the only operator using TD-5G 2500 in this region.
Do you think I can conut on adding this band to the firmware in a future update? Or it won't be worth for Netgear to add it just for one operator? In that case it it possible to change the firmware for US version? (I can see only EU version of Nighthawk M5 in online stores in Poland.) Or request for replacing the EU model for the US one, which supports n41?- TransfluxorNov 29, 2021Apprentice
Krzysiek, do not even hope, Netgear never adds bands, they have a clear division of the market by region. I myself am looking towards another 5G manufacturer - Zyxel or D-Link.
