Krzysiek
Nov 20, 2021Tutor
Enabling n41 on MR5200-100EUS
Hello, I've bought MR5200-100EUS, but it turns out there's a difference betwen 100EUS and normal version in terms of n41 support. 100EUS lacks it, but normal does have it (but doesn't have n38). n41...
Krzysiek
Nov 28, 2021Tutor
JohnPeng I found a list enumerating bands used by operators in ITU region
https://en.wikipedia.org/wiki/Mobile_network_codes_in_ITU_region_2xx_(Europe)#Poland_%E2%80%93_PL
Assuming this list is up-to-date, Plus is the only operator using TD-5G 2500 in this region.
Do you think I can conut on adding this band to the firmware in a future update? Or it won't be worth for Netgear to add it just for one operator? In that case it it possible to change the firmware for US version? (I can see only EU version of Nighthawk M5 in online stores in Poland.) Or request for replacing the EU model for the US one, which supports n41?
Transfluxor
Nov 28, 2021Apprentice
Krzysiek, do not even hope, Netgear never adds bands, they have a clear division of the market by region. I myself am looking towards another 5G manufacturer - Zyxel or D-Link.
- KrzysiekNov 28, 2021Tutor
Transfluxor wrote:they have a clear division of the market by region.
I understand that, but I'd expect that a regionalized version of a modem would support bands used in a given region.
