kapla's avatar
kapla
Enlighten Me
I'm looking for off the wall information. This is my stats:
Iphone 7plus, Trying Mint Mobile... so far works fine for what I use it for iPhone or MR1100.
Would like use it in a Rural Cabin area but 1 bar about 30ft up the hill. If I add Mimo Antenna. Can I create a passthrough (not sure if I have the right termaknowledgie). Leave the chip in my phone but run the cellular/LTE and allow it to passthrough the MR1100 (sorta as a booster). Is that doable? If I use my chip in the MR1100 it uses my Hotspot allowance. Or do I not know enough and it can't be done or there is a simpler way?
1 Reply
  • plemans's avatar
    Wouldnt work.
    You can't connect them like that and hope it works as a booster.
    sorry.
