WindyWilson
Mar 31, 2020Follower
Error message on my Nighthawk2
Hi ... hope you can help? I have the following error meesage on my Nighthawk 2 - Webkit encountered an internal error. Not sure what it means or what I need to do but I am unble to access...
michaelkenward
Apr 01, 2020Guru - Experienced User
If this is the MR2100, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Cable Modems & Routers
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I have asked the Netgear moderator to move your message.
antinode
Apr 01, 2020Guru
This must be some new meaning for "appropriate". I'd try:
https://community.netgear.com/t5/x/bd-p/aircard
Perhaps that moderator will have a better idea about the appropriate
placement of this discussion.
- JohnPengApr 02, 2020NETGEAR Expert
So factory reset can't fix the issue?
Please advise your device SKU, MR2100-xxxxxx.
Thanks
