WindyWilson
Mar 31, 2020Follower
Error message on my Nighthawk2
Hi ... hope you can help? I have the following error meesage on my Nighthawk 2 - Webkit encountered an internal error. Not sure what it means or what I need to do but I am unble to access...
antinode
Apr 01, 2020Guru
> over in the appropriate section for your device:
> Cable Modems & Routers
This must be some new meaning for "appropriate". I'd try:
https://community.netgear.com/t5/x/bd-p/aircard
> I have asked the Netgear moderator to move your message.
Perhaps that moderator will have a better idea about the appropriate
placement of this discussion.
JohnPeng
Apr 02, 2020NETGEAR Expert
So factory reset can't fix the issue?
Please advise your device SKU, MR2100-xxxxxx.
Thanks
