PMcV
Sep 23, 2024Tutor
Error Type #2 Reason #211
My Nighthawk MR6550 keeps dropping offline with the screen showing "Error Type #2 Reason #211". Netgear tech support has not been able to tell me what this means. What does it mean? Can I fix this o...
Blanca_O
Sep 29, 2024NETGEAR Employee Retired
Hi PMcV,
Please send me a private message with your support case number.
Blanca
Community Team
- templates2Oct 03, 2024AspirantHello good evening, I want to know how you managed to solve the error type 2 reason 211 I have the same device and it gives me that error, the device is unlocked and I want to put a postpaid nano verizon card in it, I have already updated the device to the firmware NTGX65_12.01.54.00
- PMcVOct 03, 2024Tutor
I never solved it, sorry. I bought one MR6550, had that problem, tech support never told me what the error meant or solved the problem, returned the device, second device had the same problem, returned it for a full refund. I also had a Verizon nano SIM, which I swapped out for another Verizon nano SIM to no avail. Was also using a Netgear MIMO antenna and confirmed the firmware was up to date. Wasted hours of my time in the process. Not sure what Netgear's problem is but both MR6550s were duds, and tech support asked a lot of questions but gave me no answers. Sorry I couldn't help you. The MR6550 is a great concept but a worthless device, and no honesty from tech support.
