PMcV
Sep 23, 2024Tutor
Error Type #2 Reason #211
My Nighthawk MR6550 keeps dropping offline with the screen showing "Error Type #2 Reason #211". Netgear tech support has not been able to tell me what this means. What does it mean? Can I fix this o...
williamBooth
Oct 22, 2024Aspirant
This device was functioning as expected with firmware 12.01.47. I just upgrade to 12.01.54 it no longer will connect. From reading the forums, it appears as though people think it's a Verizon issue. I believe it's a Netgear issue. I should probably return the device since I doubt Netgear will have this resolved anytime soon.
williamBooth
The service is now working. I have a static IP and the APN was set incorrectly after the firmware update. Now that the correct APN has been entered, all it good.
