bik3rd00d
Mar 24, 2018Tutor
Ethernet Data Offloading ... how do you get it to work?
Configuration: - brand spanky new hotspot with latest and greatest firmware downloaded on it - using my iMac to connect to and manage the wifi hotspot via 192.168.1.1 - netgear R6400 home route...
JSchnee21
Mar 25, 2018Virtuoso
Hi bik3rd00d,
Sorry, no offense intended. Your statement:
"netgear R6400 home router, plugged into cable modem
(1) I plugged the wifi hotspot into my home router."
Is what threw me off. Yes, testing at home does of course make sense. But can potentially cause issues too such as the IP conflict.
I was confusing two different settings. Do not change Port Forwarding, but due be sure that IP- Passthrough is NOT enabled (see pages 53 and 54 of manual).
It's still probably a good idea to change the base IP of the hotspot to something different than your home network. But keep in mind this will likely chaneg the IP address of the admin web page as well.
-Jonathan
bik3rd00d
Mar 27, 2018Tutor
I double checked my settings and everything is configured properly. I am also on the latest firmware for the device.
Observations:
- When I plug in the ethernet cable I see the connected device count increment by 1.
- When I unplug the ethernet cable I see the connected device count decrement by 1.
- Dashboard shows (1) ethernet data offloading configured (2) no ethernet connection
So, from my perspective either this feature simply doesn't work or I've got a defective unit. I really don't see any other choices. And I've yet to see anyone reply to this thread claiming that they have it working. PnP is working as evidence from the device connected count on the device. Not sure why ethernet would count as a device though. Doesn't seem correct. It should instead be counted as a network interface, not a device connected via wifi.
Does anyone know if the device logs anything ... e.g. var/log/... that could be inspected perhaps?
- JSchnee21Mar 27, 2018Virtuoso
Hi bik3rd00d,
I was able to get my Ethernet offloading to work at home. I had a similar IP address conflict as you did. But after I changed the IP address of the MR1100, and the DHCP range of the MR1100, all is working well. See attached screen shots -- hmmm -- haven't figured out how to upload more than one picture
Follow this proceedure:
1) connect to the web admin page on the MR1100 using Chrome (192.168.1.1)
2) Change the IP address and DHCP ranges to 192.168.0.1 and 192.168.0.10 to .99 for example. This will trigger a reboot.
3) connect to the web admin page on the MR1100 using Chrome (192.168.0.1)
4) disable Ethernet timeout
5) enable Ethernet offload
6) run Ethernet cable from the MR1100 to the LAN side of your existing home router or switch. Or the network jack in a hotel
7) IP Passthrough should be "off". DNS "auto", "use mobile router as DHCP server = checked".Under Tethering I have "Charge Only" and "Turn off Wifi when tethering = unchecked"
7) the MR1100 will display on the LCD -- a wifi and Ethernet icon. "No usage on data plan" Offloaded to Ethernet
Disable ethernet timeout
