YentelS
Oct 02, 2024Aspirant
Ethernet on my MR2100 wont work
Hi, I bought a new Netgear MR2100. Everything works fine but the ethernet port of my device wont work. I tried difficults things: resetting device, update firmware, ... but nothing seems to ...
Blanca_O
Oct 08, 2024NETGEAR Employee Retired
Hi YentelS,
Have you tried using different Ethernet Cable?
Please make sure the Ethernet cable is securely connected to both the M2 and the device you’re trying to connect.
Kindly access the M2 settings page, go to Settings > Setup > Mobile Router Setup > Ethernet Standby > select disabled > Apply
Here's a reference of how to access Mobile router settings page https://kb.netgear.com/000060946/
Blanca
Community Team
