RObVDN's avatar
RObVDN
Ethernet to Beyonwiz PVR
I am looking to use my MR1100 to connect directly to my PVR using an ethernet connection, The latest Beyonwiz firmware sems to have weakened their WiFi drivers and my WiFi connection fails very quickly. Could you please tell me what the best way to do this is? Will I lose WiFi for my other devices?
Thanks,
Rob
  • I was able to connect an ethernet cable drirectly from the router to my Beyonwiz PVR without loss of WiFi capability for other devices. ICE TV is working well on the PVR now.
    Reagrds,
    Rob
  • You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
    Mobile Routers, Hotspots & Modems
    No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
    I have asked the Netgear moderator to move your message.
  • Thanks. My problem has now been resolved and can be closed off.
    Rob
      Rob
      You could help anyone who turns up later with a similar problem by explaining how you fixed your issue.
    • RObVDN's avatar
      RObVDN
      Reagrds,
      Rob
