jarrodR
Mar 30, 2021Follower
EX6100v2 Set up as access point. Wont connect to iphone or android but will connect to laptops.
I setup the EX6100v2 as an access point. Can access the internet on my laptop using the new Hotspot I setup. And also used another laptop on the new network and it worked. But it will not allow cell ...
Mar 31, 2021Guru - Experienced User
What router is it connected to?
what firmware is on the extender?
What error are you getting from the phones/tablets?
