EMH
Jan 01, 2020Tutor
Expected Speed using MR1100 as LTE Modem?
Hello, I'm trying to help some friends that live in a rural area and are paying $$$ for slow/low bandwidth internet service. Considering recommending using the MR1100 set as LTE modem with a Net...
- Jan 09, 2020
Your setup should work.
1. Connect an ethernet cable from M1 ethernet port to Netgear WiFi router Internet port.
2. Turn off the WiFi on M1 and use the WiFi on the Netgear WiFi Router.
3. Better operate the M1 without battery, but you need to use 2amp QC charger in this case
Please let me know if you have any further questions.
Thanks
JohnPeng
Jan 09, 2020NETGEAR Expert
Thanks
- EMHMar 29, 2020Tutor
John,
Sorry for the delay in this response. For some reason I was not notified of another response (or it disappeared through user error). Anyway, I do appreciate it. I think my firends have decided to give this a try. Any further or new information/advice you could provide would also be appreciated.
