EMH's avatar
EMH
Tutor
Jan 01, 2020
Expected Speed using MR1100 as LTE Modem?
Hello,   I'm trying to help some friends that live in a rural area and are paying $$$ for slow/low bandwidth internet service. Considering recommending using the MR1100 set as LTE modem with a Net...
  • JohnPeng's avatar
    Jan 09, 2020
    Your setup should work.
    1. Connect an ethernet cable from M1 ethernet port to Netgear WiFi router Internet port.
    2. Turn off the WiFi on M1 and use the WiFi on the Netgear WiFi Router.
    3. Better operate the M1 without battery, but you need to use 2amp QC charger in this case
    Please let me know if you have any further questions.
    Thanks
