Boprince
Jun 17, 2023Aspirant
Extend 4g and 5g
We have a home in a holiday park and where our home is situated, 4g and 5g is not very good, <30mbit. At the entrance of the park, approx 200 meters/218 yards 5g is 200mbit and higher. Is there any wa...
JT240Z
Jun 18, 2023Luminary
External antennas may help in your case. Assuming your device has that capability.
- BoprinceJun 18, 2023AspirantThanks. Was thinking of buying the nighthawk 6 pro and from what I see that device has that capability. What I did notice is that the nighthawks are not waterproof so hanging it on my roof will not work. Any idea if the antennes are waterproof?
- JT240ZJun 18, 2023Luminary
The Nighthawk M6 Pro has two TS-9 antenna ports that you can plug into. They're located on the outside of the device, on same side as the USB-C and ethernet port. You can pick up a 2x2 MIMO antenna in a lot of places. Good ones are not cheap but what is when it comes to hotspots
https://waveform-content.imgix.net/ng_nighthawk-m6_ts9.png?auto=format%2Ccompress&w=960&fit=max
- BoprinceJun 18, 2023AspirantWill go and look for these antennes. Thanks for the help
