alanbow59's avatar
alanbow59
Extending Wi Fi using M6 mobile Router
Using an M6 Mobile Router. MR6110. Is there a way to extend the wi fi range when using the mobile router inside the home?
  • Thank you for the recommendation. I am not very technical, but I think I understand. The M6 connects to the cellular 5G network (to access the internet), and my devices wirelessly connect to the M6; so I guess I buy a single mesh router and physically connect it to the M6 and then connect my devices wirelessly to the mesh. Does that sound right?
    • rcpax's avatar
      rcpax
      Luminary
      yes. that way you get faster network performance inside of your network. if you extend the M6 signal, the network perfomance will be slower.
  • I would actually just use the M6 exclusively via LAN, and just get a mesh router setup if your floor area is large, and use the mesh router as your sole wifi system, instead of extending the M6's wifi range.
