JoshuaB123
Jul 05, 2019Follower
External Antennas for Netgear LB1120
Hey guys, first time posting here. So I live in The Bahamas, and we're trying to fix our LTE situation and as far as I'm aware, this LTE Modem does support GSM Carriers, such as we have here, and...
getnear666
Aug 24, 2019Aspirant
If you are that close to the tower, you might just want to put the modem upstairs at the end of a long eithernet cable.
You can get a PoE kit and still power it from the basement...
If it were me, i'd get the PoE version of this modem (LB1121) OR get a PoE adapter kit to adapt the LB1120 to PoE, like this (https://www.amazon.com/BeElion-Passive-Injector-Splitter-Connector/dp/B01HMNJHII)
or this (https://www.amazon.com/ethernet-Splitter-Compliant-Surveillance-ipolex/dp/B078LYW6D7)
and get a weather proof box and put the modem on the outside wall near the roof.
And if you are still having signal issues, get two direction antennas and connect them stight to the Modem in a weather proof box. The longer the antenna cable, the more loss, but 300' of eithernet cable will not degrade the signal.
