JeffBurnham's avatar
JeffBurnham
Follower
May 19, 2021
Factory reset netgear unite explorer2
Changed admin password but don't remember what it is want to do factory reset
1 Reply
  • michaelkenward's avatar
    michaelkenward
    I have no idea what you are trying to reset. (unite?) But the manuals always explain what to do. (Most devices also have a "reset" button on the back.)
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Look for the model number on the label on the device.
    Check the section for "factory reset" or "factiry settings".
    You may have done that already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
