Tellurium
Oct 20, 2016Apprentice
Faster version of the LB1111 4G LTE gateway?
Hello
I wanted to ask if Netgear was planning to release a new and faster version of the LB1111 in the following month?
The gateway seems great, but 150mb/s downlink is a little bit disappointing, specially since you recently released a battery powered gateway which supports 600mb/s downlink (can't remember the product name). Is there an upgraded version planned? Thank you
1 Reply
- TelluriumApprentice
I just realized that Netgear recently demoed the new MR1100 LTE Mobile Router based on the Qualcomm X16 chipset.
1Gbps download, 4x4 MIMO and LAN port. That sounds great.
https://www.youtube.com/watch?v=tPe0DU0SSX8
So my question is, can it be powered over PoE???
Do you plan to release a battery-free version, like your LB1111 PoE LTE router?
Thank you
