Fibrenetworking
May 10, 2022Tutor
Fibre Networking - POE - hyperfibre - to upgrade or not
Hi, We have a home set up with copper to fibre internet connection. We have POE to the rooms in the house via a Netgear Prosafe GS110TP and Unify wireless router system. We have ethernet ...
Fibrenetworking
May 10, 2022Tutor
Thanks - I had similar thoughts - we had hard wiring and wifi upgrade before Covid and the boys plugged in their gaming computers! We have poor phone reception and I wanted to run my mobile over wifi at home too.
May 11, 2022Guru - Experienced User
What router/satellites do you have?
What size is your home and what are the interior walls made of?
- FibrenetworkingMay 12, 2022Tutor
Hi,
Internet set up above.
Wifi wouldn't throw from a central hub hence Unify system wired and wifi system spread across the house (4 levels running down the side of the volcano - mainly stud walls but between 3 and 4 and study concrete slabs.
Thanks for the help - we are going to stick with current system until wifi 7 is up and running.
Thanks
