Djonee
Jul 29, 2020Aspirant
Find so Hard to belive that there is not solution
I Find so Hard to belive that there is not solution for a relooping Nighthawk MR1100 on boot but to send it to the company for a replacement, wich is a good thing dont get me wrong but for people lik...
icaruspony
Jul 30, 2020Luminary
1. Download AC78x Netgear drivers version 4.3.00 and install them on PC. Also, download FDT.EXE version 4.6.2.0.
2. Download MR1100 firmware (12.06.11.00 or 12.05.05.00). Put it in the same folder as FDT.EXE. Hopefully you have the generic US version of the MR1100 and not an AT&T branded version as using these firmwares on an AT&T MR1100 will permanently disable features like LAA.
3. Download and install Putty or just enable telnet in Windows (Turn Windows Features On or Off > Telnet Client).
4. Disconnect PC from Wifi and Ethernet. Your computer should have no internet connections.
5. Remove the SIM card and ethernet cable from the MR1100.
6. Factory reset the MR1100.
7. Connect the MR1100 to the PC via USB.
8. Try to connect to the MR1100 via Putty or Telnet. The IP is 192.168.1.1 with port 5510. If using telnet, the command is telnet 192.168.1.1 5510
9. Once connection is established, you may have to act quickly to halt the boot. The command is AT!BOOTHOLD
10. Open a command prompt and browse to the folder with FDT.EXE and the .SPK firmware file. Type the command fdt {firmwarefilename}.secc.spk
11. Let it do its thing. Even if there is an error that says the upgrade failed, wait 15 minutes. Eventually, it will reboot itself.
Djonee
Jul 30, 2020Aspirant
Hey , thnx for responding , that was the first method I tried but like I wrote in the post the mr1100 is looping I cant restore it to factory is unresponsive , not to every button on it but to everything, I cant make it comunicate with the pc by putty or FDT, when you say connect by USB , you mean c-type connector or the other USB male-to-male cable? belive me I've tried many times with no success
- icarusponyJul 30, 2020Luminary
The USB connection is C-type (on the MR1100) to your PC (A type).
This opens a connection that is different than Wifi or ethernet.
Are you factory resetting the device with the paperclip button under the SD card slot?
How many seconds does it take to cycle from one reboot to the next?
- drewzx3Aug 02, 2020Aspirant
Mine is doing the same exact same thing reboots about every 5 seconds and can't connect to putty
- DjoneeOct 07, 2020Aspirant
Hey my friend, I managed with all this crazyness finally flash the freaking thing, does your router keeps rebooting and at the end just the red-blue light stays flashing?
- DjoneeAug 07, 2020Aspirant
Yes I did try with the reset button too, pressing it and letting it go when when the device starts , I did it with battery ,without bat,with SIM card and without, and it restarts around 5 to 6 sec each time maybe 5 times and then stopd and the LED starts blinking red and blue for a while then it goes orange and thats it, that is all it does just one more thing if i keep pressing the power button when I connect it to the usb it goes to a DOWNLOADING SOFTWARE screen but nothing happens
- icarusponyAug 07, 2020LuminaryWhile on that "Downloading software" screen, neither Telnet nor FDT work?
