Djonee
Jul 29, 2020Aspirant
Find so Hard to belive that there is not solution
I Find so Hard to belive that there is not solution for a relooping Nighthawk MR1100 on boot but to send it to the company for a replacement, wich is a good thing dont get me wrong but for people lik...
Djonee
Jul 30, 2020Aspirant
Hey , thnx for responding , that was the first method I tried but like I wrote in the post the mr1100 is looping I cant restore it to factory is unresponsive , not to every button on it but to everything, I cant make it comunicate with the pc by putty or FDT, when you say connect by USB , you mean c-type connector or the other USB male-to-male cable? belive me I've tried many times with no success
icaruspony
Jul 30, 2020Luminary
The USB connection is C-type (on the MR1100) to your PC (A type).
This opens a connection that is different than Wifi or ethernet.
Are you factory resetting the device with the paperclip button under the SD card slot?
How many seconds does it take to cycle from one reboot to the next?
