Djonee
Jul 30, 2020Aspirant
Find so Hard to belive that there is not solution
I Find so Hard to belive that there is not solution for a relooping Nighthawk MR1100 on boot but to send it to the company for a replacement, wich is a good thing dont get me wrong but for people lik...
Djonee
Oct 07, 2020Aspirant
Hey my friend, I managed with all this crazyness finally flash the freaking thing, does your router keeps rebooting and at the end just the red-blue light stays flashing?
icaruspony
Oct 07, 2020Luminary
If you flashed it, you need to factory default it using the 30-30-30 method.
Remove battery and connect USB C power.
Hold button 30 seconds.
Pull power out, while still holding button for 30 more seconds.
Plug USB C power back in, while still holding button for 30 more seconds.
So you should be holding the button the entire minute and a half.
- icarusponyOct 07, 2020LuminaryWhen I say "button", I mean the reset button next to the SD card slot, using a paperclip.
- DjoneeOct 07, 2020Aspirant
Got it, I will try that, thnx
