Chien35
Mar 02, 2018Tutor
Firmwar update problem on Nighthawk MR1100
I'm on firmware NTG9X50C_10.12.02.01 and I have problem update the firmware. First try Check for Updates but only show CHECKING so I try Factory Reset and have the new firmware available to ...
- Mar 09, 2018
The problem is solved now because the new firmware just update today and now we can manually update the firmware by select the firmware file.
michaelkenward
Mar 03, 2018Guru - Experienced User
Chien35 wrote:
...and have the new firmware available to download but the download always failed..
What does that mean?
This link:
>>> MR1100 | Product | Support | NETGEAR <<<
suggests that there is no firmware available.
So what are you doing?
- Chien35Mar 03, 2018Tutor
- michaelkenwardMar 03, 2018Guru - Experienced User
For the benefit of other viewers.
Never seen that before.
Do you have an ad blocker active?
How are you doing this? Browser? App?
