simplicissimus
Oct 19, 2019Guide
Firmware 12.06.07 MR1100 EUS: IP Passthrough Problem
With the latest automatic firmware update my Orbi system loses the connection to the Netgear M1. It follows a pattern: - connection for 30 sec - connection lost for 5 min (obi blinks in purple ) - ...
- Oct 25, 2019Firmware 12.06.08 solves the problem. IP Passthrough with Orbi on Router mode works again.
simplicissimus
Oct 20, 2019Guide
Do you use it with a Orbi system?
simplicissimus
Oct 21, 2019Guide
I changed the Orbi to AP mode. M1 works as Router without IP Passthrough. At least, it works in this configuration again. Except all workload is done by M1 and not by Orbi. Functions like VPN doesn't work anymore .
- simplicissimusOct 25, 2019GuideFirmware 12.06.08 solves the problem. IP Passthrough with Orbi on Router mode works again.
