star96
Apr 06, 2015Novice
Firmware for Bigpond Aircard 790S
I would like to download firmware version NTG9X35C_01.03.28.05 (Build Date 2014/10/16) for my new 790S aircard (ISP is Bigpond). That is the version it currently runs. USB tethering with the IP Passt...
apac_se
Apr 07, 2015Apprentice
Hi star96,
I am a Systems Engineer for Netgear AirCard working in Australia. We recommend keeping your firmware upgraded to the latest available on our support site. You should not experience any issues with the firmware upgrade but in any case that the power or battery is removed from the device during the upgrade then you can get the device replaced through our RMA team.
Thanks.
Thanks.
