star96
Apr 06, 2015Novice
Firmware for Bigpond Aircard 790S
I would like to download firmware version NTG9X35C_01.03.28.05 (Build Date 2014/10/16) for my new 790S aircard (ISP is Bigpond). That is the version it currently runs. USB tethering with the IP Passt...
star96
Apr 08, 2015Novice
Thanks for responding.
Various tests from Win 8.1. Some via USB tethered and some via ethernet to the Billion router with the 790S tethered to the Billion.
The consistent result either way is 12-15Mbps with the 790S and 17-19Mbps on the 320U. Both devices using same roof antenna and TS-9 patch lead. So on average the 320U is about 20-30% faster download. Still on original shipped firmware.
790s USB Tethered to Windows 8.1 DC HSPA+ WCDMA 2100 RSSI -89
http://www.speedtest.net/my-result/4276011116 14Mbps
http://www.speedtest.net/my-result/4276016227 15Mbps
790s USB Tethered to Windows 8.1 on LTE Band B28 RSRP -115, Quality 24
http://www.speedtest.net/my-result/4276023049 14Mbps
http://www.speedtest.net/my-result/4276025562 13Mbps
790s USB Tethered to Windows 8.1 on LTE Band B3 RSRP -117, Quality 24
http://www.speedtest.net/my-result/4276029105 12Mbps
http://www.speedtest.net/my-result/4276032666 15Mbps
790s USB Tethered to Billion BPAC 7800VDPX on LTE Band 3 (1 bar). RSRP -119, Quality 28. Tested from Win 8.1 1000BaseT connected to Billion.
http://www.speedtest.net/my-result/4259826668 13Mbps
http://www.speedtest.net/my-result/4276044761 13Mbps
http://www.speedtest.net/my-result/4276046598 14Mbps
320U USB Tethered to Billion BPAC 7800VDPX on LTE Band 3 (1 bar). Tested from Win 8.1 1000BaseT connected to Billion.
http://www.speedtest.net/my-result/4259837350 19Mbps
http://www.speedtest.net/my-result/4259839607 17Mbps
http://www.speedtest.net/my-result/4259842208 19Mbps
